HP Mobile Thin Client mt41 Optical Disc Drive Replacement
  1. HP Mobile Thin Client mt41 Optical Disc Drive Replacement, Optical Disc Drive: step 1, image 1 of 2 HP Mobile Thin Client mt41 Optical Disc Drive Replacement, Optical Disc Drive: step 1, image 2 of 2
    • Turn off and unplug your laptop. Also, make sure to disconnect all the external devices.
    • After that, slide the two switches to the indicated directions in order to remove the battery and the back cover.
  2. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: step 2, image 1 of 2 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: step 2, image 2 of 2
    • Now you're able to remove the battery and the service cover.
    • Slide the battery upward to remove it.
  3. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: step 3, image 1 of 3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: step 3, image 2 of 3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: step 3, image 3 of 3
    • Slide the service cover downward.
    • After that, lift the back cover to remove it.
  4. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: step 4, image 1 of 3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: step 4, image 2 of 3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: step 4, image 3 of 3
    • Unlock the indicated screw in order to remove the optical drive.
    • Slide the optical drive to completely remove it from the laptop.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 447
