HP Mobile Thin Client mt41 Fan Replacement
  1. HP Mobile Thin Client mt41 Fan Replacement, Back Cover: step 1, image 1 of 2 HP Mobile Thin Client mt41 Fan Replacement, Back Cover: step 1, image 2 of 2
    • Remove the nine screws that keep the back cover secured using the T5 Torx screwdriver.
  2. HP Mobile Thin Client mt41 Fan Replacement: step 2, image 1 of 2 HP Mobile Thin Client mt41 Fan Replacement: step 2, image 2 of 2
    • Remove the middle plate using the iFixit opening tool.
    • This may require a bit of force. If it is not coming out try the other side.
  3. HP Mobile Thin Client mt41 Fan Replacement: step 3, image 1 of 1
    • Pop the back cover off from its latches by separating the two parts along their seam using the iFixit opening tool.
    • Be gentle; the plastic can crack.
  4. HP Mobile Thin Client mt41 Fan Replacement: step 4, image 1 of 1
    • Lift the back cover once all corners are unclasped from their latches.
    • Lifting the cover should not require much force.
  5. HP Mobile Thin Client mt41 Fan Replacement, Fan: step 5, image 1 of 2 HP Mobile Thin Client mt41 Fan Replacement, Fan: step 5, image 2 of 2
    • Using a J1 head for your screwdriver, remove the 4 surrounding screws.
  6. HP Mobile Thin Client mt41 Fan Replacement: step 6, image 1 of 1
    • Keep your screws close by, and slowly remove the CPU fan.
  7. HP Mobile Thin Client mt41 Fan Replacement: step 7, image 1 of 1
    • Be mindful of wires, the final step is to unplug the fan from the motherboard, at the base of red and blue wires.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 373
