HP Mobile Thin Client mt41 Back Cover Replacement
  1. HP Mobile Thin Client mt41 Back Cover Replacement, Battery: step 1, image 1 of 1
    • Locate the two slots on the bottom of the laptop to unlock the battery.
  2. HP Mobile Thin Client mt41 Back Cover Replacement: step 2, image 1 of 2 HP Mobile Thin Client mt41 Back Cover Replacement: step 2, image 2 of 2
    • Pull on both slots outwards as shown in the images to unlock the battery. The battery will not come out if the slots are locked. The battery should easily slide out without much force.
  3. HP Mobile Thin Client mt41 Back Cover Replacement, Back Cover: step 3, image 1 of 2 HP Mobile Thin Client mt41 Back Cover Replacement, Back Cover: step 3, image 2 of 2
    • Remove the nine screws that keep the back cover secured using the T5 Torx screwdriver.
  4. HP Mobile Thin Client mt41 Back Cover Replacement: step 4, image 1 of 2 HP Mobile Thin Client mt41 Back Cover Replacement: step 4, image 2 of 2
    • Remove the middle plate using the iFixit opening tool.
    • This may require a bit of force. If it is not coming out try the other side.
  5. HP Mobile Thin Client mt41 Back Cover Replacement: step 5, image 1 of 1
    • Pop the back cover off from its latches by separating the two parts along their seam using the iFixit opening tool.
    • Be gentle; the plastic can crack.
  6. HP Mobile Thin Client mt41 Back Cover Replacement: step 6, image 1 of 1
    • Lift the back cover once all corners are unclasped from their latches.
    • Lifting the cover should not require much force.
Raul Rodriguez
289 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 594
