HP Mini 210-2070NR Battery and Service Access Cover Replacement
  1. HP Mini 210-2070NR Battery and Service Access Cover Replacement, Battery and Service Access Cover: step 1, image 1 of 1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR Battery and Service Access Cover Replacement: step 2, image 1 of 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: step 2, image 2 of 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: step 2, image 3 of 3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR Battery and Service Access Cover Replacement: step 3, image 1 of 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: step 3, image 2 of 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: step 3, image 3 of 3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR Battery and Service Access Cover Replacement: step 4, image 1 of 1
    • Orient the computer as shown in the picture.
2 other people completed this guide.
Sean Kuster
91 Reputation
3 Guides authored
Cal Poly, Team 3-23, Amido Fall 2012 Member of Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 12
All Time: 1,456
