HP Mini 110-3131dx Hard Drive Replacement
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Hard Drive Replacement, Back Cover: step 2, image 1 of 2 HP Mini 110-3131dx Hard Drive Replacement, Back Cover: step 2, image 2 of 2
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Remove the four screws holding down the hard drive using a Phillips #1 screwdriver.
  3. HP Mini 110-3131dx Hard Drive Replacement: step 4, image 1 of 2 HP Mini 110-3131dx Hard Drive Replacement: step 4, image 2 of 2
    • Lift the black flap covering the hard drive then slide it towards the left using the orange tab until it's released from its receptacle.
    • Pull the hard drive out of the laptop.
    • Put the hard drive in an anti-static bag to decrease the likelihood of harming it with static electricity.
To reinstall a new or old hard drive, follow these instructions in reverse order.
3 other people completed this guide.
aarondcollege
1,297 Reputation
10 Guides authored
USF Tampa, Team 2-4, Cagle Fall 2016 Member of USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 1,433
