HP Mini 110-3131dx Fan Replacement
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Fan Replacement, Keyboard: step 2, image 1 of 1
    • Remove the three black screws marked by the keyboard symbol using a Phillips #1 screwdriver.
  2. HP Mini 110-3131dx Fan Replacement: step 3, image 1 of 3 HP Mini 110-3131dx Fan Replacement: step 3, image 2 of 3 HP Mini 110-3131dx Fan Replacement: step 3, image 3 of 3
    • Turn the laptop upright and open it.
    • Disconnect the clips located around the perimeter of the keyboard.
    • Slide the iFixit opening tool between the top edge of the keyboard and the plastic bezel.
    • Start either above the esc key or the delete key.
    • Pull the keyboard with your fingers until it comes out on both sides.
    • Be careful not to pull the keyboard out too fast. There is a fragile ribbon cable that attaches to the motherboard behind the keyboard.
  3. HP Mini 110-3131dx Fan Replacement: step 4, image 1 of 1
    • Tilt the keyboard toward you to reveal the ribbon cable.
    • Lift up the black tab on top of the keyboard ribbon cable to release the ribbon cable.
    • Pull the ribbon cable out of its container.
  4. HP Mini 110-3131dx Fan Replacement, Hard Drive: step 5, image 1 of 1
    • Remove the four screws holding down the hard drive using a Phillips #1 screwdriver.
  5. HP Mini 110-3131dx Fan Replacement: step 6, image 1 of 2 HP Mini 110-3131dx Fan Replacement: step 6, image 2 of 2
    • Lift the black flap covering the hard drive then slide it towards the left using the orange tab until it's released from its receptacle.
    • Pull the hard drive out of the laptop.
    • Put the hard drive in an anti-static bag to decrease the likelihood of harming it with static electricity.
  6. HP Mini 110-3131dx Fan Replacement, Memory Card: step 7, image 1 of 3 HP Mini 110-3131dx Fan Replacement, Memory Card: step 7, image 2 of 3 HP Mini 110-3131dx Fan Replacement, Memory Card: step 7, image 3 of 3
    • Find the two silver screws that hold the memory card cover.
    • Take a PH1 screwdriver and unscrew the two screws.
    • Remove the metal cover
  7. HP Mini 110-3131dx Fan Replacement: step 8, image 1 of 2 HP Mini 110-3131dx Fan Replacement: step 8, image 2 of 2
    • Pull the two white tabs located on either side of the memory card away from each other until the card pops up
    • Remove the card
  8. HP Mini 110-3131dx Fan Replacement, Keyboard Bezel: step 9, image 1 of 2 HP Mini 110-3131dx Fan Replacement, Keyboard Bezel: step 9, image 2 of 2
    • Remove the six black screws around the perimeter of the laptop using a Phillips #1 screwdriver.
    • Be sure to keep track of which screws go where as they are not all the same size.
    • Flip the laptop over and remove the six black screws.
  9. HP Mini 110-3131dx Fan Replacement: step 10, image 1 of 2 HP Mini 110-3131dx Fan Replacement: step 10, image 2 of 2
    • Using your fingernail or the iFixit opening tool, flip the black tab up to release the ribbon cable that connects the touchpad and motherboard.
    • Disconnect the red and black wires from the motherboard on the left-hand side of the bezel using your fingernail or iFixit opening tool.
  10. HP Mini 110-3131dx Fan Replacement: step 11, image 1 of 1
    • Lift the keyboard bezel from the back end and slide the iFixit opening tool around the perimeter of the bezel until it is fully released.
  11. HP Mini 110-3131dx Fan Replacement, Fan: step 12, image 1 of 2 HP Mini 110-3131dx Fan Replacement, Fan: step 12, image 2 of 2
    • Find the two 3.8mm screws that is holding the fan to the frame of the computer.
    • It might be required to hold wires out of the way to contact one of the screws.
    • Take out the screws with a Phillips PH1 screwdriver.
  12. HP Mini 110-3131dx Fan Replacement: step 13, image 1 of 2 HP Mini 110-3131dx Fan Replacement: step 13, image 2 of 2
    • Unplug the fan power cable by driving the connector away from the receptacle with a pry stick and one finger (or two pry sticks).
    • Raise the fan out of the computer.
3 other people completed this guide.
aarondcollege
1,297 Reputation
10 Guides authored
USF Tampa, Team 2-4, Cagle Fall 2016 Member of USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 891
