HP Media Center 876x TV Tuner Card Replacement
  1. HP Media Center 876x TV Tuner Card Replacement, Side Panel: step 1, image 1 of 2 HP Media Center 876x TV Tuner Card Replacement, Side Panel: step 1, image 2 of 2
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x TV Tuner Card Replacement: step 2, image 1 of 3 HP Media Center 876x TV Tuner Card Replacement: step 2, image 2 of 3 HP Media Center 876x TV Tuner Card Replacement: step 2, image 3 of 3
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x TV Tuner Card Replacement, TV Tuner Card: step 3, image 1 of 2 HP Media Center 876x TV Tuner Card Replacement, TV Tuner Card: step 3, image 2 of 2
    • Identify the TV tuner card (distal from the cooling fan, in the lower-left corner of the tower).
    • Using a #0 Phillips head screwdriver, remove the one (6 mm) screw fastening the TV tuner card into its slot.
  4. HP Media Center 876x TV Tuner Card Replacement: step 4, image 1 of 2 HP Media Center 876x TV Tuner Card Replacement: step 4, image 2 of 2
    • Gently pull the card vertically out of its port.
Balakrishnan Pillai
1,003 Reputation
8 Guides authored
Clemson, Team 6-1, Benson Spring 2014 Member of Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
3 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 634
