HP Media Center 876x Optical Drive Replacement
  1. HP Media Center 876x Optical Drive Replacement, Side Panel: step 1, image 1 of 2 HP Media Center 876x Optical Drive Replacement, Side Panel: step 1, image 2 of 2
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x Optical Drive Replacement: step 2, image 1 of 3 HP Media Center 876x Optical Drive Replacement: step 2, image 2 of 3 HP Media Center 876x Optical Drive Replacement: step 2, image 3 of 3
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x Optical Drive Replacement, Front Cover: step 3, image 1 of 2 HP Media Center 876x Optical Drive Replacement, Front Cover: step 3, image 2 of 2
    • Orient the tower vertically.
    • Using the #0 Phillips head screwdriver, unscrew and remove the two (5 mm) screws that fasten the remaining side panel to the tower.
    • Slide the side panel out of its notches, and pull it gently off of the tower.
  4. HP Media Center 876x Optical Drive Replacement: step 4, image 1 of 1
    • Gently move the tower so that it is in the horizontal orientation.
    • Press down the black tabs (proximal to you) that fasten the front panel to the tower.
    • Press down on the distal, black tabs (symmetric with respect to the previous tabs).
    • Pull front panel forward slightly.
  5. HP Media Center 876x Optical Drive Replacement: step 5, image 1 of 2 HP Media Center 876x Optical Drive Replacement: step 5, image 2 of 2
    • The front panel will come off in a hinge-like fashion, exposing the drives underneath.
  6. HP Media Center 876x Optical Drive Replacement, Optical Drive: step 6, image 1 of 3 HP Media Center 876x Optical Drive Replacement, Optical Drive: step 6, image 2 of 3 HP Media Center 876x Optical Drive Replacement, Optical Drive: step 6, image 3 of 3
    • Identify the optical drive.
    • Pull the molex connectors out of the posterior end of the optical drive.
  7. HP Media Center 876x Optical Drive Replacement: step 7, image 1 of 3 HP Media Center 876x Optical Drive Replacement: step 7, image 2 of 3 HP Media Center 876x Optical Drive Replacement: step 7, image 3 of 3
    • Pull the ribbon cable out of the back of the optical drive.
  8. HP Media Center 876x Optical Drive Replacement: step 8, image 1 of 3 HP Media Center 876x Optical Drive Replacement: step 8, image 2 of 3 HP Media Center 876x Optical Drive Replacement: step 8, image 3 of 3
    • Using the Phillips #0 screwdriver, remove the two 5 mm screws that fasten the optical drive into its port.
    • Gently pull the optical drive through the front cavity.
  9. HP Media Center 876x Optical Drive Replacement: step 9, image 1 of 2 HP Media Center 876x Optical Drive Replacement: step 9, image 2 of 2
    • Remove the optical drive completely from its port.
2 other people completed this guide.
Balakrishnan Pillai
1,003 Reputation
8 Guides authored
Clemson, Team 6-1, Benson Spring 2014 Member of Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
3 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 379
