HP Media Center 876x Cooling Fan Replacement
  1. HP Media Center 876x Cooling Fan Replacement, Side Panel: step 1, image 1 of 2 HP Media Center 876x Cooling Fan Replacement, Side Panel: step 1, image 2 of 2
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x Cooling Fan Replacement: step 2, image 1 of 3 HP Media Center 876x Cooling Fan Replacement: step 2, image 2 of 3 HP Media Center 876x Cooling Fan Replacement: step 2, image 3 of 3
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x Cooling Fan Replacement, Cooling Fan: step 3, image 1 of 2 HP Media Center 876x Cooling Fan Replacement, Cooling Fan: step 3, image 2 of 2
    • Apply great pressure with fingers on the tabs of the fan casing.
    • While applying pressure, pull the casing upwards to remove.
  4. HP Media Center 876x Cooling Fan Replacement: step 4, image 1 of 2 HP Media Center 876x Cooling Fan Replacement: step 4, image 2 of 2
    • Simultaneously pull the four corner tabs outward.
    • Grab the center of the fan and slide it, smoothly, outward.
  5. HP Media Center 876x Cooling Fan Replacement: step 5, image 1 of 2 HP Media Center 876x Cooling Fan Replacement: step 5, image 2 of 2
    • Remove the fan completely from its casing.
    • Take care not to damage any plastic parts or wires.
Balakrishnan Pillai
1,003 Reputation
8 Guides authored
Clemson, Team 6-1, Benson Spring 2014 Member of Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
3 Members
15 Guides authored
One Comment
Cpu not start
Sameer - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 25
All Time: 519
