HP HDX 16-1160US Battery Replacement
  1. HP HDX 16-1160US Battery Replacement, Battery: step 1, image 1 of 1
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US Battery Replacement: step 2, image 1 of 3 HP HDX 16-1160US Battery Replacement: step 2, image 2 of 3 HP HDX 16-1160US Battery Replacement: step 2, image 3 of 3
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US Battery Replacement: step 3, image 1 of 1
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
2 other people completed this guide.
Daniel McBroom
278 Reputation
2 Guides authored
Cal Poly, Team 12-38, Maness Spring 2014 Member of Cal Poly, Team 12-38, Maness Spring 2014
CPSU-MANESS-S14S12G38
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 729
