HP G60T-600 CTO Hard drive Replacement
  1. HP G60T-600 CTO Hard drive Replacement, Battery: step 1, image 1 of 1
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. HP G60T-600 CTO Hard drive Replacement: step 2, image 1 of 2 HP G60T-600 CTO Hard drive Replacement: step 2, image 2 of 2
    • Place your index finger on the ridged tab.
  3. HP G60T-600 CTO Hard drive Replacement: step 3, image 1 of 1
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  4. HP G60T-600 CTO Hard drive Replacement, Hard drive: step 4, image 1 of 2 HP G60T-600 CTO Hard drive Replacement, Hard drive: step 4, image 2 of 2
    • Remove the 5cm screws with a #00 Phillips screwdriver.
    • Take the cover off.
  5. HP G60T-600 CTO Hard drive Replacement: step 5, image 1 of 3 HP G60T-600 CTO Hard drive Replacement: step 5, image 2 of 3 HP G60T-600 CTO Hard drive Replacement: step 5, image 3 of 3
    • Remove the following .5cm screws with a #0 Phillips screwdriver.
    • Slide the hard drive cover to the right with light-medium force.
  6. HP G60T-600 CTO Hard drive Replacement: step 6, image 1 of 1
    • Pull up on the little black tab on the hard drive case to remove it.
    • From here you will be able to carefully slide your hard drive out.
Dominic DeSantis
772 Reputation
6 Guides authored
UMass Dartmouth, Team 4-5, Catania Fall 2016 Member of UMass Dartmouth, Team 4-5, Catania Fall 2016
UMASSD-CATANIA-F16S4G5
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 179
