HP EliteOne 800 G1 Power Supply Replacement
  1. HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: step 1, image 1 of 3 HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: step 1, image 2 of 3 HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: step 1, image 3 of 3
    • Place computer with the screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Power Supply Replacement, Removing Stand: step 2, image 1 of 2 HP EliteOne 800 G1 Power Supply Replacement, Removing Stand: step 2, image 2 of 2
    • Press locking latch on the bottom of the base of the stand.
    • Pull the plastic cover off of the stand.
  3. HP EliteOne 800 G1 Power Supply Replacement: step 3, image 1 of 2 HP EliteOne 800 G1 Power Supply Replacement: step 3, image 2 of 2
    • Use a Torx T15 driver and stick it through the holes on the stand in order to remove the two 12mm screws on the back of the main unit.
    • Tilt stand and lift up to remove it.
  4. HP EliteOne 800 G1 Power Supply Replacement: step 4, image 1 of 2 HP EliteOne 800 G1 Power Supply Replacement: step 4, image 2 of 2
    • Use a Torx T15 driver to remove the single 10mm screw on the back panel.
    • Pull the back panel toward the bottom of the device to remove it.
  5. HP EliteOne 800 G1 Power Supply Replacement, Power Supply: step 5, image 1 of 2 HP EliteOne 800 G1 Power Supply Replacement, Power Supply: step 5, image 2 of 2
    • Use a Torx T15 driver to remove the four 10mm screws on the VESA mount cover.
    • Lift up on the VESA mount cover to remove it.
  6. HP EliteOne 800 G1 Power Supply Replacement: step 6, image 1 of 1
    • Disconnect the power supply's black and yellow cable from the motherboard.
  7. HP EliteOne 800 G1 Power Supply Replacement: step 7, image 1 of 2 HP EliteOne 800 G1 Power Supply Replacement: step 7, image 2 of 2
    • Use a Torx T15 driver to remove the two 8mm screws on either side of the power supply.
    • Lift the power supply from the case to remove it.
6 other people completed this guide.
Michael Ewing
1,071 Reputation
4 Guides authored
Cal Poly, Team 1-24, Maness Fall 2015 Member of Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 54
All Time: 5,315
