HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement
  1. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: step 1, image 1 of 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: step 1, image 2 of 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: step 1, image 3 of 3
    • Place the computer screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: step 2, image 1 of 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: step 2, image 2 of 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: step 2, image 3 of 3
    • Grasp the handle on the hard drive cage to the left of the stand. It is marked with green.
    • Pull the handle up, allowing the entire cage to slide toward the outward edge of the computer.
    • Pull the entire cage up and out of the device.
  3. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: step 3, image 1 of 2 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: step 3, image 2 of 2
    • Once the cage is out of the device, use a Torx T15 driver to unscrew the four 10mm screws keeping the drive in place. There are two screws on each side.
    • Once all the screws are removed, lift the drive out of the cage.
4 other people completed this guide.
Kyle Koivuniemi
605 Reputation
3 Guides authored
Cal Poly, Team 1-24, Maness Fall 2015 Member of Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
4 Members
14 Guides authored
2 Comments
where can i buy a replace cage for the hard drive?
Thomas Dickson - Reply
What replacement guide can I buy for my HP EliteOne 800 G1 all in one?
Hank Trujillo - Reply
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 88
All Time: 8,443
