HP EliteOne 800 G1 Fan Assembly Replacement
  1. HP EliteOne 800 G1 Fan Assembly Replacement, Removing the Back Cover: step 1, image 1 of 3 HP EliteOne 800 G1 Fan Assembly Replacement, Removing the Back Cover: step 1, image 2 of 3 HP EliteOne 800 G1 Fan Assembly Replacement, Removing the Back Cover: step 1, image 3 of 3
    • Place computer with the screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Fan Assembly Replacement, Removing Stand: step 2, image 1 of 2 HP EliteOne 800 G1 Fan Assembly Replacement, Removing Stand: step 2, image 2 of 2
    • Press locking latch on the bottom of the base of the stand.
    • Pull the plastic cover off of the stand.
  3. HP EliteOne 800 G1 Fan Assembly Replacement: step 3, image 1 of 2 HP EliteOne 800 G1 Fan Assembly Replacement: step 3, image 2 of 2
    • Use a Torx T15 driver and stick it through the holes on the stand in order to remove the two 12mm screws on the back of the main unit.
    • Tilt stand and lift up to remove it.
  4. HP EliteOne 800 G1 Fan Assembly Replacement: step 4, image 1 of 2 HP EliteOne 800 G1 Fan Assembly Replacement: step 4, image 2 of 2
    • Use a Torx T15 driver to remove the single 10mm screw on the back panel.
    • Pull the back panel toward the bottom of the device to remove it.
  5. HP EliteOne 800 G1 Fan Assembly Replacement, Fan Assembly: step 5, image 1 of 1
    • Disconnect these two power connectors on the motherboard, one connector is white and the other is black. You can identify the correct wires by their braided colors: red, yellow, blue, and black.
  6. HP EliteOne 800 G1 Fan Assembly Replacement: step 6, image 1 of 2 HP EliteOne 800 G1 Fan Assembly Replacement: step 6, image 2 of 2
    • Use a Torx T15 driver to remove the three 6mm screws surrounding the fan assembly.
    • Pull the fan assembly up from the case to remove it.
5 other people completed this guide.
Michael Ewing
1,071 Reputation
4 Guides authored
Cal Poly, Team 1-24, Maness Fall 2015 Member of Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 40
All Time: 6,806
