Introduction
There are many ways screens can get damaged, and sometimes it is hard to identify a damaged screen if doesn’t work and it’s not cracked. If you do believe the screen is bad, don’t worry, replacing the screen is not as bad as you think. This guide will show you how to replace the screen in an HP EliteBook 8530w laptop.
Turn the laptop off then place it down so that the back is facing up.
Slide the battery release switch to the left and hold it there.
Turn the laptop off then place it down so that the top is facing up, then open the laptop.
Remove the six screws around the screen bezel using a Phillips #00 screwdriver.
Lift the screen from the frame at the top of the laptop.
At the bottom of the screen, there will be a cable connected to the body of the laptop. Remove this cable.
On the back of the screen, there will be a ribbon cable that connects to it. Remove this cable by pinching the two tabs on the ends of the connector and pull outwards.
One Comment
Hi! I have this laptop and i got a problem. Laptop starts but it's not showing nothing on the screen. If i remove the RAM memory i cannot here any sound from the motherboard so i think that the problem it is not in the screen and it's on the motherboard. What kind of test i could make to check my theory? Could be the BIOS too? Any help pls
