HP Elite x2 1012 G2 Speakers Replacement
  1. HP Elite x2 1012 G2 Speakers Replacement, Screen: step 1, image 1 of 1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Speakers Replacement: step 2, image 1 of 3 HP Elite x2 1012 G2 Speakers Replacement: step 2, image 2 of 3 HP Elite x2 1012 G2 Speakers Replacement: step 2, image 3 of 3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Speakers Replacement: step 3, image 1 of 2 HP Elite x2 1012 G2 Speakers Replacement: step 3, image 2 of 2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Speakers Replacement: step 4, image 1 of 1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Speakers Replacement: step 5, image 1 of 3 HP Elite x2 1012 G2 Speakers Replacement: step 5, image 2 of 3 HP Elite x2 1012 G2 Speakers Replacement: step 5, image 3 of 3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Speakers Replacement: step 6, image 1 of 2 HP Elite x2 1012 G2 Speakers Replacement: step 6, image 2 of 2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Speakers Replacement, Speakers: step 7, image 1 of 1
    • Identify the speaker locations.
  8. HP Elite x2 1012 G2 Speakers Replacement: step 8, image 1 of 2 HP Elite x2 1012 G2 Speakers Replacement: step 8, image 2 of 2
    • Remove the antennae connections from both the WiFi card and the wireless cellular M.2 card.
    • Gently pull the black and red wire free at the motherboard connector.
  9. HP Elite x2 1012 G2 Speakers Replacement: step 9, image 1 of 3 HP Elite x2 1012 G2 Speakers Replacement: step 9, image 2 of 3 HP Elite x2 1012 G2 Speakers Replacement: step 9, image 3 of 3
    • Use the spudger tool to remove the speakers from the housing.
  10. HP Elite x2 1012 G2 Speakers Replacement: step 10, image 1 of 2 HP Elite x2 1012 G2 Speakers Replacement: step 10, image 2 of 2
    • On the right speaker, the black antena piece must be removed before the speaker can be accessed.
  11. HP Elite x2 1012 G2 Speakers Replacement: step 11, image 1 of 2 HP Elite x2 1012 G2 Speakers Replacement: step 11, image 2 of 2
    • Now remove the green and white wires from the cable management track and the speakers will be completely removed from the device.
WesleyEagleson
431 Reputation
3 Guides authored
IUPUI, Team S13-G13, Wilson Spring 2019 Member of IUPUI, Team S13-G13, Wilson Spring 2019
IUPUI-WILSON-S19S13G13
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 32
All Time: 1,228
