HP Deskjet 3000 j310a Repair Printer Cover Replacement
  1. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Disconnect Printer: step 1, image 1 of 1
    • Begin to disassemble the printer by disconnecting from all power sources and computers. Keep cords separate and allow the printer to cool for 5 minutes.
  2. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Remove Bottom Cover: step 2, image 1 of 1
    • Flip the printer upside down and locate the cover on the left hand side. It is rectangular shape and is held in place by two screws. Unscrew these screws and take off cover.
  3. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Release Paper Output Tray: step 3, image 1 of 1
    • To release the tray from the printer, you must manually pull it out. Hold the tray and push towards one side of the printer. Then pull away from the printer towards the other side. Keep output tray separate.
  4. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Unscrew Cover: step 4, image 1 of 1
    • Turn the printer upside down. Locate the four screws holding the cover in place. These will be on the edges of the cover.
  5. HP Deskjet 3000 j310a Repair Printer Cover Replacement: step 5, image 1 of 1
    • Unscrew the four screws, keeping them separate. Turn the printer back right side up
  6. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Pull Off Top: step 6, image 1 of 1
    • Place fingers on the edge of the red cover. Begin to pull upwards to release the top portion, working your way around the printer. Make sure that it does not fall back into place.
  7. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Disconnect Cover: step 7, image 1 of 2 HP Deskjet 3000 j310a Repair Printer Cover Replacement, Disconnect Cover: step 7, image 2 of 2
    • Once the top is loose, there will still be a connection wire between the printer and the cover. This wire will be about one inch wide and white, located under the buttons.
  8. HP Deskjet 3000 j310a Repair Printer Cover Replacement: step 8, image 1 of 2 HP Deskjet 3000 j310a Repair Printer Cover Replacement: step 8, image 2 of 2
    • Detach the wire from the printer by pulling the blue-sealed end from the white holder.
tdambruoso
491 Reputation
4 Guides authored
UMass Dartmouth, Team 1-5, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-5, Duarte Fall 2014
UMASSD-DUARTE-F14S1G5
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 41
All Time: 494
