HP Compaq Presario cq62-214nr Motherboard Replacement
  1. HP Compaq Presario cq62-214nr Motherboard Replacement, Keyboard: step 1, image 1 of 2 HP Compaq Presario cq62-214nr Motherboard Replacement, Keyboard: step 1, image 2 of 2
    • With all the screws removed from the previous guides. Remove the final eight M2.5X5 mm Philips screws on the back of the laptop
  2. HP Compaq Presario cq62-214nr Motherboard Replacement: step 2, image 1 of 2 HP Compaq Presario cq62-214nr Motherboard Replacement: step 2, image 2 of 2
    • In the battery housing, there are three screws that hold the keyboard on. These screws are located on the side near the front.
    • In the center of the bottom of the computer between the RAM and the wifi antenna is a 4th keyboard screw that also needs to be removed.
  3. HP Compaq Presario cq62-214nr Motherboard Replacement: step 3, image 1 of 3 HP Compaq Presario cq62-214nr Motherboard Replacement: step 3, image 2 of 3 HP Compaq Presario cq62-214nr Motherboard Replacement: step 3, image 3 of 3
    • Open up the front of the laptop. Use a plastic opening tool to carefully pry open the keyboard from the edges.
  4. HP Compaq Presario cq62-214nr Motherboard Replacement: step 4, image 1 of 1
    • Remove the keyboard by pulling on it with your hands.
    • There is a ribbon cable that is still connected on the back of the keyboard. Do not pull off the ribbon cable when pulling up the keyboard.
  5. HP Compaq Presario cq62-214nr Motherboard Replacement: step 5, image 1 of 3 HP Compaq Presario cq62-214nr Motherboard Replacement: step 5, image 2 of 3 HP Compaq Presario cq62-214nr Motherboard Replacement: step 5, image 3 of 3
    • Locate the keyboard cable/wire that attaches the keyboard to the laptop .
    • Locate the latch of the wire connector
    • Unlatch the wire connector and gently pull out the wire with your hands
  6. HP Compaq Presario cq62-214nr Motherboard Replacement, Motherboard: step 6, image 1 of 1
    • Remove the four M2.5x5 mm Phillips screws from the exposed keyboard cover.
  7. HP Compaq Presario cq62-214nr Motherboard Replacement: step 7, image 1 of 3 HP Compaq Presario cq62-214nr Motherboard Replacement: step 7, image 2 of 3 HP Compaq Presario cq62-214nr Motherboard Replacement: step 7, image 3 of 3
    • Locate the three tab holding down the cover of the Motherboard.
    • Lift the tabs with using either a plastic opening tool or your fingers.
  8. HP Compaq Presario cq62-214nr Motherboard Replacement: step 8, image 1 of 2 HP Compaq Presario cq62-214nr Motherboard Replacement: step 8, image 2 of 2
    • Using a plastic opening tool to lift the sides of the cover.
  9. HP Compaq Presario cq62-214nr Motherboard Replacement: step 9, image 1 of 3 HP Compaq Presario cq62-214nr Motherboard Replacement: step 9, image 2 of 3 HP Compaq Presario cq62-214nr Motherboard Replacement: step 9, image 3 of 3
    • Use your hands to gently lift the cover off.
  10. HP Compaq Presario cq62-214nr Motherboard Replacement: step 10, image 1 of 3 HP Compaq Presario cq62-214nr Motherboard Replacement: step 10, image 2 of 3 HP Compaq Presario cq62-214nr Motherboard Replacement: step 10, image 3 of 3
    • Locate the four cables securing the Motherboard.
    • Gently pull cables to unsecure them.
  11. HP Compaq Presario cq62-214nr Motherboard Replacement: step 11, image 1 of 3 HP Compaq Presario cq62-214nr Motherboard Replacement: step 11, image 2 of 3 HP Compaq Presario cq62-214nr Motherboard Replacement: step 11, image 3 of 3
    • Remove the three M2.25x5 mm Phillips screws.
  12. HP Compaq Presario cq62-214nr Motherboard Replacement: step 12, image 1 of 3 HP Compaq Presario cq62-214nr Motherboard Replacement: step 12, image 2 of 3 HP Compaq Presario cq62-214nr Motherboard Replacement: step 12, image 3 of 3
    • Unlatch the final cable and gently remove the Motherboard.
3 other people completed this guide.
Roth Marcelin
726 Reputation
6 Guides authored
USF Tampa, Team 2-6, Sullivan Fall 2016 Member of USF Tampa, Team 2-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G6
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 22
All Time: 1,075
