HP Chromebook 14-x010wm Motherboard Replacement
  1. HP Chromebook 14-x010wm Motherboard Replacement, Motherboard: step 1, image 1 of 2 HP Chromebook 14-x010wm Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Start with unscrewing all 16 5.7mm screws from the bottom of the laptop.
    • Make sure to remove the rubber pads covering 4 of the screws near the back of the laptop.
  2. HP Chromebook 14-x010wm Motherboard Replacement: step 2, image 1 of 1
    • Pop the clips around the perimeter of the keyboard tray.
  3. HP Chromebook 14-x010wm Motherboard Replacement: step 3, image 1 of 1
    • Lift the keyboard tray carefully and disconnect the ribbon cables before setting it aside.
  4. HP Chromebook 14-x010wm Motherboard Replacement: step 4, image 1 of 2 HP Chromebook 14-x010wm Motherboard Replacement: step 4, image 2 of 2
    • The motherboard is located in the top left corner of the laptop.
    • Be sure to disconnect the battery as well as any other connectors on the motherboard.
    • We recommend a prying motion on the two power cords seen in the top right of the motherboard.
  5. HP Chromebook 14-x010wm Motherboard Replacement: step 5, image 1 of 1
    • Remove all the screws securing the motherboard down.
  6. HP Chromebook 14-x010wm Motherboard Replacement: step 6, image 1 of 1
    • Remove the copper heat sink and then remove the motherboard using a tilting motion for the ports to slip out of the plastic casing.
3 other people completed this guide.
Tyler
190 Reputation
1 Guide authored
IUPUI, Team 1-1, Harley Spring 2022 Member of IUPUI, Team 1-1, Harley Spring 2022
IUPUI-HARLEY-S22S1G1
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 213
