HP Chromebook 14-x010wm Charging Port Replacement
  1. HP Chromebook 14-x010wm Charging Port Replacement, Battery: step 1, image 1 of 3 HP Chromebook 14-x010wm Charging Port Replacement, Battery: step 1, image 2 of 3 HP Chromebook 14-x010wm Charging Port Replacement, Battery: step 1, image 3 of 3
    • Remove the thirteen 5.7mm screws from the back of the laptop using a Phillips #00 screwdriver.
    • Remove rubber covers to reveal concealed screws, as needed.
  2. HP Chromebook 14-x010wm Charging Port Replacement: step 2, image 1 of 3 HP Chromebook 14-x010wm Charging Port Replacement: step 2, image 2 of 3 HP Chromebook 14-x010wm Charging Port Replacement: step 2, image 3 of 3
    • Flip the laptop over carefully and open the cover.
    • Use a plastic opening tool to pry open the front edge and along the sides of the keyboard cover to separate it from the computer’s base.
    • Lift the keyboard cover from the computer’s base carefully.
  3. HP Chromebook 14-x010wm Charging Port Replacement: step 3, image 1 of 3 HP Chromebook 14-x010wm Charging Port Replacement: step 3, image 2 of 3 HP Chromebook 14-x010wm Charging Port Replacement: step 3, image 3 of 3
    • Lifting the keyboard cover too much may damage the internal cables of the laptop.
    • Lift the black plastic flap, using a plastic opening tool, of the zero insertion force (ZIF) connector that holds the keyboard cable in place.
    • Disconnect the keyboard cable by slowly pulling it from the system board.
    • Lift the black plastic flap that holds the battery cable in place using a plastic opening tool.
    • Remove the battery cable by slowly pulling the plastic connector towards you.
    • Remove carefully and set aside keyboard panel.
  4. HP Chromebook 14-x010wm Charging Port Replacement: step 4, image 1 of 2 HP Chromebook 14-x010wm Charging Port Replacement: step 4, image 2 of 2
    • Flip the plastic flap holding the battery cable using a plastic opening tool.
    • Disconnect the battery cable by carefully pulling it from the system board.
  5. HP Chromebook 14-x010wm Charging Port Replacement: step 5, image 1 of 3 HP Chromebook 14-x010wm Charging Port Replacement: step 5, image 2 of 3 HP Chromebook 14-x010wm Charging Port Replacement: step 5, image 3 of 3
    • Remove the seven M2xL3.0 screws from around the battery using a Phillips #00 screwdriver.
  6. HP Chromebook 14-x010wm Charging Port Replacement: step 6, image 1 of 2 HP Chromebook 14-x010wm Charging Port Replacement: step 6, image 2 of 2
    • Peel the wire band off of the battery carefully.
    • Remove the battery by lifting slightly, then slowly pull it towards you.
  7. HP Chromebook 14-x010wm Charging Port Replacement, Charging Port: step 7, image 1 of 3 HP Chromebook 14-x010wm Charging Port Replacement, Charging Port: step 7, image 2 of 3 HP Chromebook 14-x010wm Charging Port Replacement, Charging Port: step 7, image 3 of 3
    • Use a plastic opening tool to undo the tabs securing the charging port.
    • Then gently lift the port up and away from the laptop edge.
  8. HP Chromebook 14-x010wm Charging Port Replacement: step 8, image 1 of 3 HP Chromebook 14-x010wm Charging Port Replacement: step 8, image 2 of 3 HP Chromebook 14-x010wm Charging Port Replacement: step 8, image 3 of 3
    • Use a plastic opening tool to pry both ends of the corresponding white plug from it's port at the motherboard.
    • Carefully pull the plug out of the port.
Rachel Clevidence
89 Reputation
1 Guide authored
IUPUI, Team S3-G3, Harley Spring 2019 Member of IUPUI, Team S3-G3, Harley Spring 2019
IUPUI-HARLEY-S19S3G3
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 1,027
