HP Chromebook 14-Q070NR Keyboard Replacement
  1. HP Chromebook 14-Q070NR Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Keyboard Replacement: step 2, image 1 of 3 HP Chromebook 14-Q070NR Keyboard Replacement: step 2, image 2 of 3 HP Chromebook 14-Q070NR Keyboard Replacement: step 2, image 3 of 3
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Keyboard Replacement: step 3, image 1 of 3 HP Chromebook 14-Q070NR Keyboard Replacement: step 3, image 2 of 3 HP Chromebook 14-Q070NR Keyboard Replacement: step 3, image 3 of 3
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Keyboard Replacement: step 4, image 1 of 3 HP Chromebook 14-Q070NR Keyboard Replacement: step 4, image 2 of 3 HP Chromebook 14-Q070NR Keyboard Replacement: step 4, image 3 of 3
    • Once the ribbons are detached, remove the keyboard from the device.
Alexandra Bagarra
122 Reputation
1 Guide authored
USF Tampa, Team S9-G5, Remmell Fall 2017 Member of USF Tampa, Team S9-G5, Remmell Fall 2017
USFT-REMMELL-F17S9G5
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 303
