HP 8 1401 Front-Facing Camera Replacement
  1. HP 8 1401 Front-Facing Camera Replacement, Back Panel: step 1, image 1 of 1
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
  2. HP 8 1401 Front-Facing Camera Replacement: step 2, image 1 of 1
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
  3. HP 8 1401 Front-Facing Camera Replacement: step 3, image 1 of 2 HP 8 1401 Front-Facing Camera Replacement: step 3, image 2 of 2
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
  4. HP 8 1401 Front-Facing Camera Replacement, Front-Facing Camera: step 4, image 1 of 1
    • Place the tip of your spudger under the edge of the press fit connector, and pry the connector straight up from its socket.
  5. HP 8 1401 Front-Facing Camera Replacement: step 5, image 1 of 2 HP 8 1401 Front-Facing Camera Replacement: step 5, image 2 of 2
    • Lift the front-facing camera out of the tablet.
  6. HP 8 1401 Front-Facing Camera Replacement: step 6, image 1 of 1
    • After the front-facing camera has been removed, the tablet should look like this.
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 126
