HP 8 1401 Battery Replacement
  1. HP 8 1401 Battery Replacement, Back Panel: step 1, image 1 of 1
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
  2. HP 8 1401 Battery Replacement: step 2, image 1 of 1
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
  3. HP 8 1401 Battery Replacement: step 3, image 1 of 2 HP 8 1401 Battery Replacement: step 3, image 2 of 2
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
  4. HP 8 1401 Battery Replacement, Battery: step 4, image 1 of 2 HP 8 1401 Battery Replacement, Battery: step 4, image 2 of 2
    • Using a spudger or your fingers, disconnect the power cable by sliding the connector out of the socket on the motherboard.
  5. HP 8 1401 Battery Replacement: step 5, image 1 of 1
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Using a plastic card or a nylon spudger, carefully pry the battery from the adhesive on the tablet.
    • Do not use a metal spudger, which may damage/puncture the battery and pose a hazard.
  6. HP 8 1401 Battery Replacement: step 6, image 1 of 1
    • Once the battery is removed the battery and tablet should look like this.
0 Comments
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 5
All Time: 885
