HP 7 PLUS 1301 Volume / Power Button Replacement
  1. HP 7 PLUS 1301 Volume / Power Button  Replacement, Volume / Power Button: step 1, image 1 of 2 HP 7 PLUS 1301 Volume / Power Button  Replacement, Volume / Power Button: step 1, image 2 of 2
    • Make sure the device is off and not plugged in before starting.
    • Use the T5 Torx screwdriver and remove the T5x3mm screws on all four corners of the device.
  2. HP 7 PLUS 1301 Volume / Power Button  Replacement: step 2, image 1 of 2 HP 7 PLUS 1301 Volume / Power Button  Replacement: step 2, image 2 of 2
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Volume / Power Button  Replacement: step 3, image 1 of 2 HP 7 PLUS 1301 Volume / Power Button  Replacement: step 3, image 2 of 2
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Volume / Power Button  Replacement: step 4, image 1 of 1
    • The power and volume buttons are on the side of the device. Locate these buttons to begin the replacement process.
  5. HP 7 PLUS 1301 Volume / Power Button  Replacement: step 5, image 1 of 2 HP 7 PLUS 1301 Volume / Power Button  Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Gently push out the power and volume buttons with tweezers.
Adanna Ilori
301 Reputation
2 Guides authored
UC Davis, Team S20-G6, Lore Winter 2019 Member of UC Davis, Team S20-G6, Lore Winter 2019
UCD-LORE-W19S20G6
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 232
