HP 310-1037 Motherboard Replacement
  1. HP 310-1037 Motherboard Replacement, Hard Drive: step 1, image 1 of 3 HP 310-1037 Motherboard Replacement, Hard Drive: step 1, image 2 of 3 HP 310-1037 Motherboard Replacement, Hard Drive: step 1, image 3 of 3
    • HP310-1037 Touchsmart PC with a dead hard drive. The hard drive is located behind the stand cover.
    • Lay the PC flat on the front to gain access to the stand cover
    • Remove the single screw that holds the stand cover to the chassis with a flat tip screwdriver
  2. HP 310-1037 Motherboard Replacement: step 2, image 1 of 3 HP 310-1037 Motherboard Replacement: step 2, image 2 of 3 HP 310-1037 Motherboard Replacement: step 2, image 3 of 3
    • Remove the stand cover
    • The hard drive caddy is held in place with 1 Phillips screw
    • Use a #0 Phillips screwdriver to remove that screw
  3. HP 310-1037 Motherboard Replacement: step 3, image 1 of 3 HP 310-1037 Motherboard Replacement: step 3, image 2 of 3 HP 310-1037 Motherboard Replacement: step 3, image 3 of 3
    • Lift the handle on the hard drive caddy
    • and pull it to the backside. This will remove the hard drive caddy from the computer.
    • To remove the hard drive from the caddy, turn it over. There are four Phillips scres that hold the hard drive in place.
  4. HP 310-1037 Motherboard Replacement: step 4, image 1 of 2 HP 310-1037 Motherboard Replacement: step 4, image 2 of 2
    • Once the four screws are removed, slide the hard drive out of the caddy.
    • Here is the failed drive. It is a Hitachi HDS721010CLA332. Failure with this drive is all to common.
  5. HP 310-1037 Motherboard Replacement, Remove stand: step 5, image 1 of 1
    • Remove the four Torx/Flathead screws securing the stand.
    • Lift the bottom part of the stand upwards, and it will come off.
  6. HP 310-1037 Motherboard Replacement, Remove back cover: step 6, image 1 of 1
    • Remove the four Torx/Flathead screws securing the back cover.
    • Also unscrew the two captive Philips screws securing the disc drive, as these two screws also secure the back cover.
  7. HP 310-1037 Motherboard Replacement, Remove metal shield: step 7, image 1 of 1
    • Remove the seven silver Torx/Flathead screws securing the metal shield.
    • Remove the single black Torx/Flathead screw securing the metal shield.
    • Remove the cables strung through the shield.
    • Pull up on the shield to remove it.
  8. HP 310-1037 Motherboard Replacement, Remove fan: step 8, image 1 of 1
    • Remove the two Torx/Flathead screws securing the fan.
    • Pull up on the fan connector to remove it.
    • Lift the fan to remove it.
  9. HP 310-1037 Motherboard Replacement, Remove heatsink assembly: step 9, image 1 of 1
    • Remove the six Philips screws securing the heatsink assembly to the motherboard.
    • Carefully lift the heatsink. If it won't come off, twist it as you pull it off. If it still won't come off, pull harder.
    • Unfortunately, if you have to resort to pulling harder, the processor will likely come off with the heatsink. If this happens, use an adjustable heat gun set to ~200C to soften the thermal paste, first.
  10. HP 310-1037 Motherboard Replacement, Remove motherboard: step 10, image 1 of 1
    • Remove all attached connectors from the motherboard.
    • Remove the four remaining screws securing the motherboard. You're done!
Joseph Sctbunio
7,332 Reputation
42 Guides authored
One Comment
How do u take the DVD drive out?
Sam's Tech Review - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 44
All Time: 1,865
