HP 15-ac121dx Fan Replacement
  1. HP 15-ac121dx Fan Replacement, Battery: step 1, image 1 of 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Fan Replacement: step 2, image 1 of 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Fan Replacement: step 3, image 1 of 2 HP 15-ac121dx Fan Replacement: step 3, image 2 of 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Fan Replacement: step 4, image 1 of 2 HP 15-ac121dx Fan Replacement: step 4, image 2 of 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Fan Replacement, Back Panel: step 5, image 1 of 3 HP 15-ac121dx Fan Replacement, Back Panel: step 5, image 2 of 3 HP 15-ac121dx Fan Replacement, Back Panel: step 5, image 3 of 3
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac121dx Fan Replacement: step 6, image 1 of 1
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac121dx Fan Replacement: step 7, image 1 of 3 HP 15-ac121dx Fan Replacement: step 7, image 2 of 3 HP 15-ac121dx Fan Replacement: step 7, image 3 of 3
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac121dx Fan Replacement, Fan: step 8, image 1 of 3 HP 15-ac121dx Fan Replacement, Fan: step 8, image 2 of 3 HP 15-ac121dx Fan Replacement, Fan: step 8, image 3 of 3
    • Locate the Fan as shown.
    • Pull out the black cable, with four wires attached from its port.
  9. HP 15-ac121dx Fan Replacement: step 9, image 1 of 2 HP 15-ac121dx Fan Replacement: step 9, image 2 of 2
    • Pull out the white cable wire from its port.
    • Unscrew the two black Phillips screws holding in the fan.
  10. HP 15-ac121dx Fan Replacement: step 10, image 1 of 2 HP 15-ac121dx Fan Replacement: step 10, image 2 of 2
    • Remove fan.
    • Unscrew the two screws holding in the fan.
Replace fan. To reassemble your device, follow these instructions in reverse order.
Onose Aigbe
390 Reputation
3 Guides authored
Baylor, Team S1-G2, Johnson Spring 2018 Member of Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,428
