GuliKit KingKong 2 Pro Triggers Replacement
  1. GuliKit KingKong 2 Pro Triggers Replacement, Unfasten the back cover screws: step 1, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the four 11 mm-long screws securing the back cover.
  2. GuliKit KingKong 2 Pro Triggers Replacement, Insert an opening pick: step 2, image 1 of 2 GuliKit KingKong 2 Pro Triggers Replacement, Insert an opening pick: step 2, image 2 of 2
    • The back cover of the GuliKit Kingkong 2 Pro is held in place by plastic clips.
    • Insert an opening pick into the gap between the front assembly and the back cover at the bottom edge of the controller.
    • Tilt your opening pick downwards to widen the gap.
  3. GuliKit KingKong 2 Pro Triggers Replacement, Separate the front assembly and back cover: step 3, image 1 of 2 GuliKit KingKong 2 Pro Triggers Replacement, Separate the front assembly and back cover: step 3, image 2 of 2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the right controller handle.
    • Slide the opening pick along the gap to separate the front assembly from the back cover.
  4. GuliKit KingKong 2 Pro Triggers Replacement: step 4, image 1 of 2 GuliKit KingKong 2 Pro Triggers Replacement: step 4, image 2 of 2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the left controller handle.
  5. GuliKit KingKong 2 Pro Triggers Replacement, Remove the back cover: step 5, image 1 of 2 GuliKit KingKong 2 Pro Triggers Replacement, Remove the back cover: step 5, image 2 of 2
    • Separate the back cover from the front assembly and remove it.
  6. GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the right vibration motor: step 6, image 1 of 3 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the right vibration motor: step 6, image 2 of 3 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the right vibration motor: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • It's not mandatory to remove the two vibration motors to remove the mainboard assembly. However, other repairs become much easier with the motors removed. If you want to leave the motors in place, you can jump straight to step 9.
    • Pull on the connectors themselves and not the cables to avoid damaging them.
    • Use the point of a spudger to disconnect the right vibration motor by pushing the connector straight out of its socket.
    • If you can't disconnect the vibration motor with a spudger, use a pair of blunt nose tweezers to pull the connector out of its socket.
  7. GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the left vibration motor: step 7, image 1 of 3 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the left vibration motor: step 7, image 2 of 3 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the left vibration motor: step 7, image 3 of 3
    • Use the point of a spudger to disconnect the left vibration motor by pushing the connector straight out of its socket.
  8. GuliKit KingKong 2 Pro Triggers Replacement, Remove the vibration motors: step 8, image 1 of 1
    • Remove the vibration motors by lifting them out of the controller housing.
  9. GuliKit KingKong 2 Pro Triggers Replacement, Release the interconnect cable ZIF connector: step 9, image 1 of 2 GuliKit KingKong 2 Pro Triggers Replacement, Release the interconnect cable ZIF connector: step 9, image 2 of 2
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable's ZIF connector.
  10. GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the interconnect cable: step 10, image 1 of 2 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the interconnect cable: step 10, image 2 of 2
    • Use a pair of blunt nose tweezers to disconnect the interconnect cable by pulling the cable straight out of the connector.
  11. GuliKit KingKong 2 Pro Triggers Replacement, Unfasten the mainboard assembly screws: step 11, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the screws securing the mainboard assembly:
    • Four 7.8 mm-long screws.
    • Two 11 mm-long screws.
  12. GuliKit KingKong 2 Pro Triggers Replacement, Remove the mainboard shield: step 12, image 1 of 2 GuliKit KingKong 2 Pro Triggers Replacement, Remove the mainboard shield: step 12, image 2 of 2
    • Use a pair of blunt nose tweezers to remove the metal shield from the mainboard assembly.
  13. GuliKit KingKong 2 Pro Triggers Replacement, Remove the mainboard assembly: step 13, image 1 of 3 GuliKit KingKong 2 Pro Triggers Replacement, Remove the mainboard assembly: step 13, image 2 of 3 GuliKit KingKong 2 Pro Triggers Replacement, Remove the mainboard assembly: step 13, image 3 of 3
    • Remove the mainboard assembly by lifting it out of the controller housing.
  14. GuliKit KingKong 2 Pro Triggers Replacement, Unfasten the battery frame screw: step 14, image 1 of 1
    • Take care not to puncture the battery with your tool—a punctured battery may leak dangerous chemicals or cause a fire.
    • Use a Phillips #00 screwdriver to remove the single 7.8 mm-long screw securing the battery frame.
  15. GuliKit KingKong 2 Pro Triggers Replacement, Free the battery frame: step 15, image 1 of 3 GuliKit KingKong 2 Pro Triggers Replacement, Free the battery frame: step 15, image 2 of 3 GuliKit KingKong 2 Pro Triggers Replacement, Free the battery frame: step 15, image 3 of 3
    • Free the battery frame by lifting it off the plastic pins holding it in place.
  16. GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the battery: step 16, image 1 of 2 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the battery: step 16, image 2 of 2
    Buy
    • Use a pair of blunt nose tweezers to disconnect the battery connector by pulling it straight out of its socket.
    • Remove the battery and its frame from the controller housing.
  17. GuliKit KingKong 2 Pro Triggers Replacement, Unfasten the trigger screws: step 17, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the four 7.8 mm-long screws securing the triggers.
  18. GuliKit KingKong 2 Pro Triggers Replacement, Remove the left trigger: step 18, image 1 of 3 GuliKit KingKong 2 Pro Triggers Replacement, Remove the left trigger: step 18, image 2 of 3 GuliKit KingKong 2 Pro Triggers Replacement, Remove the left trigger: step 18, image 3 of 3
    • Use your fingers to lift the left trigger off its bracket.
    • Remove the left trigger.
  19. GuliKit KingKong 2 Pro Triggers Replacement, Remove the right trigger: step 19, image 1 of 3 GuliKit KingKong 2 Pro Triggers Replacement, Remove the right trigger: step 19, image 2 of 3 GuliKit KingKong 2 Pro Triggers Replacement, Remove the right trigger: step 19, image 3 of 3
    • Repeat the previous procedure and lift the right trigger off its bracket to remove it.
Dominik Schnabelrauch
206,326 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,523 Guides authored
6 Comments
Do you know where to buy a replacement zr trigger? The Black piece of Plastic,as in your last picture ,is broken on mine.
Strumpfmaskenmann - Reply
My Gulikit Kingkong 2 (non-pro) controller bought in Dec 2022 only uses PH01 screws. No PH00 ones. Otherwise this guide is very helpful for any disassembly you may want to do.
Sebastian Jost - Reply
When replacing the triggers, you need to recalibrate the controller before the new trigger(s) will work. I followed I followed the instructions found here for recalibrating when updating the firmware.
"Just press the four buttons of L,R,left of D-pad and A at the same time to quickly calibrate the sticks ZR,ZL with a vibration to solve this issue"
Captain Tinman - Reply
Did anyone find a retailer for a replacement trigger
Max Lang - Reply
Mate. You just show how to remove the triggers. How bout replacement ?????
John Robert Caleja - Reply
Past 24 Hours: 9
Past 7 Days: 36
Past 30 Days: 153
All Time: 5,243
