Graco Secure Coverage Nursery Unit Power Jack Replacement
  1. Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Battery: step 1, image 1 of 3 Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Battery: step 1, image 2 of 3 Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Battery: step 1, image 3 of 3
    • Remove the 9mm screw from the battery cover of the nursery unit using a Phillips #1 tip screwdriver.
  2. Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 2, image 1 of 2 Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 2, image 2 of 2
    • Using the plastic opening tool, pry and remove the battery cover carefully.
    • Remove the batteries using plastic opening tool.
    • Replace the batteries.
  3. Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Power Jack: step 3, image 1 of 2 Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Power Jack: step 3, image 2 of 2
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • Place the screws in a secure place.
  4. Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 4, image 1 of 1
    • Hold the bottom of the device with one hand and pull down to separate the front and rare cases.
    • While holding the device with one hand, use plastic opening tool to pry the edges of the front case away from the back case.
    • Take your time and apply constant force carefully to avoid breaking any other plastic parts from the device.
  5. Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 5, image 1 of 2 Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 5, image 2 of 2
    • Remove all three 7mm Phillips #1 screws from the mother board.
    • Make sure you gently unscrew the screws with moderate force and light pressure to avoid any damages.
  6. Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 6, image 1 of 2 Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 6, image 2 of 2
    • Pick up the mother board carefully.
    • Using plastic opening tool, gently pry the power jack plastic part and separate it away from the device case.
    • Apply constant force to avoid breaking the plastic part.
  7. Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 7, image 1 of 1
    • Solder off the wires from the mother board.
    • There are many pins attached to the mother board, make sure you solder off the proper pins that attached to the power jack wires.
    • Replace the power jack.
Omar Abdullah
201 Reputation
2 Guides authored
USF Tampa, Team 6-5, Remmell Fall 2015 Member of USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 146
