Gateway P-7805u RAM Replacement
  1. Gateway P-7805u RAM Replacement, RAM: step 1, image 1 of 2 Gateway P-7805u RAM Replacement, RAM: step 1, image 2 of 2
    • Use the J0 screwdriver to remove the five 2mm screws holding the back plate.
  2. Gateway P-7805u RAM Replacement: step 2, image 1 of 1
    • Push the upper RAM module's two pins outwards at the same time.
    • If done correctly, the module should lift.
  3. Gateway P-7805u RAM Replacement: step 3, image 1 of 2 Gateway P-7805u RAM Replacement: step 3, image 2 of 2
    • Grab onto the module and pull away in a straight direction.
  4. Gateway P-7805u RAM Replacement: step 4, image 1 of 2 Gateway P-7805u RAM Replacement: step 4, image 2 of 2
    • Push the lower RAM module's two pins outwards at the same time.
    • If done correctly, the module should have lifted.
Emily Pendleton
401 Reputation
4 Guides authored
Baylor, Team S8-G6, Johnson Fall 2017 Member of Baylor, Team S8-G6, Johnson Fall 2017
BU-JOHNSON-F17S8G6
2 Members
8 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 14
All Time: 297
