Gateway P-6831FX WiFi Card Replacement
  1. Gateway P-6831FX WiFi Card Replacement, WiFi Card: step 1, image 1 of 2 Gateway P-6831FX WiFi Card Replacement, WiFi Card: step 1, image 2 of 2
    • Turn your laptop upside down and remove the five Philips #0 (5mm) screws for the cover of the WiFi Card.
    • Make sure to unplug your laptop charger, as removing the WiFi while the device is charging may damage the WiFi and or the charger.
  2. Gateway P-6831FX WiFi Card Replacement: step 2, image 1 of 2 Gateway P-6831FX WiFi Card Replacement: step 2, image 2 of 2
    • Gently pull the cover away from the device.
  3. Gateway P-6831FX WiFi Card Replacement: step 3, image 1 of 3 Gateway P-6831FX WiFi Card Replacement: step 3, image 2 of 3 Gateway P-6831FX WiFi Card Replacement: step 3, image 3 of 3
    • Remove the three wires above the WiFi Card.
    • Take note of the color for each wire and it's corresponding location.
  4. Gateway P-6831FX WiFi Card Replacement: step 4, image 1 of 3 Gateway P-6831FX WiFi Card Replacement: step 4, image 2 of 3 Gateway P-6831FX WiFi Card Replacement: step 4, image 3 of 3
    • Remove the two Phillips #0 (2mm) screws above the WiFi card.
    • The WiFi Card will lift up once the screws are removed.
  5. Gateway P-6831FX WiFi Card Replacement: step 5, image 1 of 2 Gateway P-6831FX WiFi Card Replacement: step 5, image 2 of 2
    • With the WiFi Card lifted up, gently pull the WiFi Card out of the socket and remove it from the device.
Chandler Jardin
507 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 17
All Time: 431
