Gateway P-6831FX Hard Drive Replacement
  1. Gateway P-6831FX Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Gateway P-6831FX Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Turn your laptop upside down and remove the four Philips #0 (5mm) screws for the cover of the hard drive.
    • Make sure to unplug your laptop charger, as removing the hard drive while the device is charging may damage the hard drive and or the charger.
  2. Gateway P-6831FX Hard Drive Replacement: step 2, image 1 of 2 Gateway P-6831FX Hard Drive Replacement: step 2, image 2 of 2
    • Gently pull the cover away from the device.
    • Set the cover aside for now, until reassembly.
  3. Gateway P-6831FX Hard Drive Replacement: step 3, image 1 of 2 Gateway P-6831FX Hard Drive Replacement: step 3, image 2 of 2
    • Pull the plastic tab as shown to remove the hard drive from the device.
  4. Gateway P-6831FX Hard Drive Replacement: step 4, image 1 of 2 Gateway P-6831FX Hard Drive Replacement: step 4, image 2 of 2
    • Remove the four Philips #0 (3mm) screws around the case for the hard drive. There will be two screws and the left and right side.
  5. Gateway P-6831FX Hard Drive Replacement: step 5, image 1 of 3 Gateway P-6831FX Hard Drive Replacement: step 5, image 2 of 3 Gateway P-6831FX Hard Drive Replacement: step 5, image 3 of 3
    • Remove the hard drive from the case.
Chandler Jardin
507 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 13
All Time: 309
