Gateway P-6831FX Battery Replacement
  1. Gateway P-6831FX Battery Replacement, Battery: step 1, image 1 of 1
    • Turn your laptop upside down and locate the 1st unlocking switch.
    • Make sure to unplug your laptop charger, as removing the battery while the device is charging may damage the battery and or the charger.
  2. Gateway P-6831FX Battery Replacement: step 2, image 1 of 2 Gateway P-6831FX Battery Replacement: step 2, image 2 of 2
    • Put the switch from the locked position to the unlocked position.
  3. Gateway P-6831FX Battery Replacement: step 3, image 1 of 2 Gateway P-6831FX Battery Replacement: step 3, image 2 of 2
    • Slide the lock to the right to unlock the battery from the device.
  4. Gateway P-6831FX Battery Replacement: step 4, image 1 of 2 Gateway P-6831FX Battery Replacement: step 4, image 2 of 2
    • While holding the 2nd lock in the unlocked position, pull the battery away from the laptop.
Justin Freitas
294 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 14
All Time: 238
