Gateway NV57H50u Hard Drive Replacement
  1. Gateway NV57H50u Hard Drive Replacement, Battery: step 1, image 1 of 3 Gateway NV57H50u Hard Drive Replacement, Battery: step 1, image 2 of 3 Gateway NV57H50u Hard Drive Replacement, Battery: step 1, image 3 of 3
    • Push orange locking tab with spudger right, until battery lifts out of place.
    • Laptop should be unplugged from power supply before removal.
  2. Gateway NV57H50u Hard Drive Replacement, Rear Cover: step 2, image 1 of 1
    • Unscrew the two 7 mm long #0 Phillips screws.
  3. Gateway NV57H50u Hard Drive Replacement: step 3, image 1 of 1
    • Lift and remove the cover panel via the indentation in the middle of the panel.
  4. Gateway NV57H50u Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • Push spudger to the left until hard drive is moved from its original position.
  5. Gateway NV57H50u Hard Drive Replacement: step 5, image 1 of 1
    • Pull plastic flap and pull hard drive away from laptop.
Aaron Allison
433 Reputation
5 Guides authored
IUPUI, Team S1-G1, Baechle Fall 2018 Member of IUPUI, Team S1-G1, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G1
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 707
