Gateway NE56R Series Hard Drive Replacement
  1. Gateway NE56R Series Hard Drive Replacement, Remove hard drive cover: step 1, image 1 of 2 Gateway NE56R Series Hard Drive Replacement, Remove hard drive cover: step 1, image 2 of 2
    • Remove the two Philips screws securing the hard drive cover to the base.
    • Pry the hard drive cover off with a spudger.
  2. Gateway NE56R Series Hard Drive Replacement, Remove hard drive caddy: step 2, image 1 of 1
    • With the laptop's battery side facing you, pull the hard drive caddy's tab to the right.
  3. Gateway NE56R Series Hard Drive Replacement, Remove hard drive: step 3, image 1 of 1
    • This step is unnecessary if you are only taking the hard drive out for testing purposes or are removing the motherboard.
    • Remove the four screws securing the hard drive to the caddy.
2 other people completed this guide.
Joseph Sctbunio
7,332 Reputation
42 Guides authored
2 Comments
Very helpful now I need to know how to replace the mother board from the same machine as the Hard drive.
Michael K - Reply
Does replacement of harddrive effect memory?
Nathaniel TRotter - Reply
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 25
All Time: 1,654
