Gateway NE51006u RAM Replacement
  1. Gateway NE51006u RAM Replacement, Hard Drive: step 1, image 1 of 1
    • Ensure device is powered off and unplugged from a power source. Place the device upside down.
  2. Gateway NE51006u RAM Replacement: step 2, image 1 of 1
    • Use a PH0 Phillips head screwdriver to remove the 9.0 mm screw on the rectangular panel underneath the device.
  3. Gateway NE51006u RAM Replacement: step 3, image 1 of 1
    • Use a plastic opening tool to pry open the rectangular panel the 9.0 mm screw was removed from.
  4. Gateway NE51006u RAM Replacement: step 4, image 1 of 3 Gateway NE51006u RAM Replacement: step 4, image 2 of 3 Gateway NE51006u RAM Replacement: step 4, image 3 of 3
    • Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive.
  5. Gateway NE51006u RAM Replacement: step 5, image 1 of 3 Gateway NE51006u RAM Replacement: step 5, image 2 of 3 Gateway NE51006u RAM Replacement: step 5, image 3 of 3
    • Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing.
  6. Gateway NE51006u RAM Replacement, RAM: step 6, image 1 of 3 Gateway NE51006u RAM Replacement, RAM: step 6, image 2 of 3 Gateway NE51006u RAM Replacement, RAM: step 6, image 3 of 3
    • Use your fingers to pull the two metal hinges on either side of the RAM card.
    • From here the card should lift upwards and pull off of the device easily.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 315
