Gateway MS2285 Battery Replacement
  1. Gateway MS2285 Battery Replacement, Turn Laptop Over: step 1, image 1 of 1
    • Turn the laptop over so that the underside is facing towards you.
  2. Gateway MS2285 Battery Replacement, Unlock The Battery: step 2, image 1 of 2 Gateway MS2285 Battery Replacement, Unlock The Battery: step 2, image 2 of 2
    • Slide the short slider one towards the unlocked lock symbol.
  3. Gateway MS2285 Battery Replacement, Release The Battery: step 3, image 1 of 2 Gateway MS2285 Battery Replacement, Release The Battery: step 3, image 2 of 2
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
  4. Gateway MS2285 Battery Replacement, Remove The Battery: step 4, image 1 of 2 Gateway MS2285 Battery Replacement, Remove The Battery: step 4, image 2 of 2
    • Grasp the battery's raised end and lift upwards.
Chris mello
331 Reputation
3 Guides authored
UMass Dartmouth, Team 1-7, Shastany Fall 2014 Member of UMass Dartmouth, Team 1-7, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G7
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 1,249
