Gateway MD2614u Internal Modem Replacement
  1. Gateway MD2614u Internal Modem Replacement, Back Cover: step 1, image 1 of 1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Internal Modem Replacement: step 2, image 1 of 1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Internal Modem Replacement: step 3, image 1 of 1
    • Lift off the cover.
  4. Gateway MD2614u Internal Modem Replacement, Internal Modem: step 4, image 1 of 1
    • The internal modem will be located towards the bottom right of the laptop (highlighted with a yellow square).
  5. Gateway MD2614u Internal Modem Replacement: step 5, image 1 of 1
    • Using a Phillips #00 screwdriver, unscrew both of the screws that are holding the modem in place.
  6. Gateway MD2614u Internal Modem Replacement: step 6, image 1 of 1
    • Carefully pry the modem as to not damage any of the surrounding components
  7. Gateway MD2614u Internal Modem Replacement: step 7, image 1 of 1
    • Using needle nose pliers, carefully detach the wire connecting the modem, by applying pressure to the black tabs away from the modem itself.
  8. Gateway MD2614u Internal Modem Replacement: step 8, image 1 of 1
    • Success! You've removed the internal modem!
Nelson
201 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 6
All Time: 382
