Gateway MA7 CD/DVD Drive Replacement
  1. Gateway MA7 CD/DVD Drive Replacement, CD/DVD Drive: step 1, image 1 of 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Push the locking tab over to the right away from the battery to unlock it from the laptop.
    • Hold the additional locking tab to the left while puling out the battery.
  2. Gateway MA7 CD/DVD Drive Replacement: step 2, image 1 of 2 Gateway MA7 CD/DVD Drive Replacement: step 2, image 2 of 2
    • Remove the following screws securing the plastic panel from the bottom of the laptop:
    • Remove the seven 6 mm screws with a Phillips #0 screwdriver
  3. Gateway MA7 CD/DVD Drive Replacement: step 3, image 1 of 3 Gateway MA7 CD/DVD Drive Replacement: step 3, image 2 of 3 Gateway MA7 CD/DVD Drive Replacement: step 3, image 3 of 3
    • Pull upwards on the top of the plastic panel to remove it.
    • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
  4. Gateway MA7 CD/DVD Drive Replacement: step 4, image 1 of 2 Gateway MA7 CD/DVD Drive Replacement: step 4, image 2 of 2
    • Remove the following screws holding the DVD/CD drive in place:
    • One 6 mm Phillips #0
  5. Gateway MA7 CD/DVD Drive Replacement: step 5, image 1 of 1
    • Use the edge of a plastic opening tool to push down on the metal latch preventing the drive from being pushed out.
    • While pressing down, push the metal latch out away from the laptop.
  6. Gateway MA7 CD/DVD Drive Replacement: step 6, image 1 of 3 Gateway MA7 CD/DVD Drive Replacement: step 6, image 2 of 3 Gateway MA7 CD/DVD Drive Replacement: step 6, image 3 of 3
    • Once the drive has been pried out, you can pull the CD drive out.
Tim Rose
392 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 14
All Time: 484
