Gateway M-2626u RAM Replacement
  1. Gateway M-2626u RAM  Replacement, Battery: step 1, image 1 of 1
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u RAM  Replacement: step 2, image 1 of 3 Gateway M-2626u RAM  Replacement: step 2, image 2 of 3 Gateway M-2626u RAM  Replacement: step 2, image 3 of 3
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u RAM  Replacement, Back Panel: step 3, image 1 of 2 Gateway M-2626u RAM  Replacement, Back Panel: step 3, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  4. Gateway M-2626u RAM  Replacement: step 4, image 1 of 2 Gateway M-2626u RAM  Replacement: step 4, image 2 of 2
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
  5. Gateway M-2626u RAM  Replacement, RAM: step 5, image 1 of 1
    • Remember to always remove or disconnect the battery!
    • Push outwards on the metal tab to unlock the RAM stick from its position.
  6. Gateway M-2626u RAM  Replacement: step 6, image 1 of 2 Gateway M-2626u RAM  Replacement: step 6, image 2 of 2
    • Lift up and remove the RAM from the device.
    • Follow the same steps to remove the second RAM stick from your device.
Tanya Jain
317 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 150
