Gateway M-2626u Hard Drive Replacement
  1. Gateway M-2626u Hard Drive Replacement, Battery: step 1, image 1 of 1
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u Hard Drive Replacement: step 2, image 1 of 3 Gateway M-2626u Hard Drive Replacement: step 2, image 2 of 3 Gateway M-2626u Hard Drive Replacement: step 2, image 3 of 3
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Gateway M-2626u Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the three 6mm screws holding the hard drive panel in place.
  4. Gateway M-2626u Hard Drive Replacement: step 4, image 1 of 1
    • Using the plastic opening tool, pry open the plastic panel covering the hard drive.
  5. Gateway M-2626u Hard Drive Replacement: step 5, image 1 of 3 Gateway M-2626u Hard Drive Replacement: step 5, image 2 of 3 Gateway M-2626u Hard Drive Replacement: step 5, image 3 of 3
    • Using your hands, carefully pull out the hard drive from its compartment.
Femi
219 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 223
