Gateway M-2626u CPU Replacement
  1. Gateway M-2626u CPU Replacement, Back Panel: step 1, image 1 of 2 Gateway M-2626u CPU Replacement, Back Panel: step 1, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  2. Gateway M-2626u CPU Replacement: step 2, image 1 of 2 Gateway M-2626u CPU Replacement: step 2, image 2 of 2
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
  3. Gateway M-2626u CPU Replacement, CPU Fan: step 3, image 1 of 2 Gateway M-2626u CPU Replacement, CPU Fan: step 3, image 2 of 2
    • Remove the header by pulling on it with two fingers.
  4. Gateway M-2626u CPU Replacement: step 4, image 1 of 1
    • Remove the six 2.5mm screws using a Phillips #1 screwdriver.
  5. Gateway M-2626u CPU Replacement: step 5, image 1 of 1
    • Remove the fan by moving it to the side and lifting it out of the computer.
  6. Gateway M-2626u CPU Replacement, CPU: step 6, image 1 of 1
    • Once the fan is removed, locate the CPU.
    • Rotate the plastic knob using a flat head screw driver as depicted in this image
  7. Gateway M-2626u CPU Replacement: step 7, image 1 of 1
    • Lift and remove the CPU from the mother board socket.
Armani Tayeh
432 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 241
