Gateway KAV60 LT2016U RAM Replacement
  1. Gateway KAV60 LT2016U RAM Replacement, Battery: step 1, image 1 of 3 Gateway KAV60 LT2016U RAM Replacement, Battery: step 1, image 2 of 3 Gateway KAV60 LT2016U RAM Replacement, Battery: step 1, image 3 of 3
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U RAM Replacement, RAM: step 2, image 1 of 1
    • The RAM is located under this cover.
  3. Gateway KAV60 LT2016U RAM Replacement: step 3, image 1 of 3 Gateway KAV60 LT2016U RAM Replacement: step 3, image 2 of 3 Gateway KAV60 LT2016U RAM Replacement: step 3, image 3 of 3
    • Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place.
    • Use a plastic opening tool to remove the cover.
  4. Gateway KAV60 LT2016U RAM Replacement: step 4, image 1 of 2 Gateway KAV60 LT2016U RAM Replacement: step 4, image 2 of 2
    • Unlock the RAM by pinching the metal clamps that keep the RAM in place.
    • Remove the RAM while the metal clamps are disengaged.
Lydia Benjock
1,216 Reputation
10 Guides authored
Clemson, Team 14-3, Benson Fall 2013 Member of Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Members
22 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 17
All Time: 2,101
