Gateway KAV60 LT2016U Hard Drive Replacement
  1. Gateway KAV60 LT2016U Hard Drive Replacement, Battery: step 1, image 1 of 3 Gateway KAV60 LT2016U Hard Drive Replacement, Battery: step 1, image 2 of 3 Gateway KAV60 LT2016U Hard Drive Replacement, Battery: step 1, image 3 of 3
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U Hard Drive Replacement, Hard Drive: step 2, image 1 of 1
    • The hard drive is located under this cover.
  3. Gateway KAV60 LT2016U Hard Drive Replacement: step 3, image 1 of 2 Gateway KAV60 LT2016U Hard Drive Replacement: step 3, image 2 of 2
    • Remove the two (2) 5mm screws holding the cover down using the Phillips #0 screwdriver.
  4. Gateway KAV60 LT2016U Hard Drive Replacement: step 4, image 1 of 2 Gateway KAV60 LT2016U Hard Drive Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to lift the cover.
  5. Gateway KAV60 LT2016U Hard Drive Replacement: step 5, image 1 of 1
    • Using a Phillips #0 screwdriver, remove a third 5mm screw that holds the second cover that is directly protecting the hard drive.
  6. Gateway KAV60 LT2016U Hard Drive Replacement: step 6, image 1 of 3 Gateway KAV60 LT2016U Hard Drive Replacement: step 6, image 2 of 3 Gateway KAV60 LT2016U Hard Drive Replacement: step 6, image 3 of 3
    • Slide the silver cover up; the hole on the cover and the hole for the screw will no longer match up.
    • Lift the silver cover; this will expose the hard drive.
Lydia Benjock
1,216 Reputation
10 Guides authored
Clemson, Team 14-3, Benson Fall 2013 Member of Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Members
22 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 16
All Time: 1,658
