Gateway 600YG2 CPU Replacement
  1. Gateway 600YG2 CPU Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 CPU Replacement: step 2, image 1 of 1
    • Remove the battery cover using the tab on the right side.
    • Take the battery out with your index finger.
  3. Gateway 600YG2 CPU Replacement, Power Button Panel: step 3, image 1 of 1
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
  4. Gateway 600YG2 CPU Replacement, Keyboard: step 4, image 1 of 1
    • Remove the 5 screws holding the keyboard in place.
  5. Gateway 600YG2 CPU Replacement: step 5, image 1 of 2 Gateway 600YG2 CPU Replacement: step 5, image 2 of 2
    • Potential for device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
    • Potential for device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
    • Follow the black ribbon cable to the connector and gently pull straight up.
  6. Gateway 600YG2 CPU Replacement, System Fan: step 6, image 1 of 2 Gateway 600YG2 CPU Replacement, System Fan: step 6, image 2 of 2
    • Unscrew the four captive screws.
    • Unplug the fan from the system and pull it out. The fan unit should slide forward before coming free.
  7. Gateway 600YG2 CPU Replacement, CPU: step 7, image 1 of 1
    • Turn screw 1/4 turn to the right.
    • When reinstalling ensure proper orientation the yellow arrow on CPU should be in upper left corner
Elizabeth Mazer
78 Reputation
10 Guides authored
Cal Poly, Team 20-10, Maness Fall 2010 Member of Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Members
22 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 17
All Time: 1,953
