Gateway 3545GZ Hard Drive Replacement
  1. Gateway 3545GZ Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Flip the laptop so that the bottom is facing you. You will find in the lower left-hand corner a hole with a small screw; unscrew this with a PH1 Phillips-head screwdriver (Has a plus shape).
    • Screw Length: 3mm
  2. Gateway 3545GZ Hard Drive Replacement: step 2, image 1 of 1
    • Lift up the plastic plate from the outer edge.
  3. Gateway 3545GZ Hard Drive Replacement: step 3, image 1 of 1
    • Finally, slide the hard drive out of its dock; then just lift the hard drive out of the pocket.
Bryan Rickle
1 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 14
All Time: 281
