Garmin nuviCam LMTHD Speaker Replacement
  1. Garmin nuviCam LMTHD Speaker Replacement, Screen: step 1, image 1 of 2 Garmin nuviCam LMTHD Speaker Replacement, Screen: step 1, image 2 of 2
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Speaker Replacement: step 2, image 1 of 2 Garmin nuviCam LMTHD Speaker Replacement: step 2, image 2 of 2
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Speaker Replacement: step 3, image 1 of 1
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Speaker Replacement: step 4, image 1 of 2 Garmin nuviCam LMTHD Speaker Replacement: step 4, image 2 of 2
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Speaker Replacement, Speaker: step 5, image 1 of 2 Garmin nuviCam LMTHD Speaker Replacement, Speaker: step 5, image 2 of 2
    • Locate the speaker in the corner opposite of the dashcam.
    • Pry speaker out of device using a plastic opening tool.
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 9
All Time: 433
