Garmin nuviCam LMTHD Motherboard Replacement
  1. Garmin nuviCam LMTHD Motherboard Replacement, Screen: step 1, image 1 of 2 Garmin nuviCam LMTHD Motherboard Replacement, Screen: step 1, image 2 of 2
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Motherboard Replacement: step 2, image 1 of 2 Garmin nuviCam LMTHD Motherboard Replacement: step 2, image 2 of 2
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Motherboard Replacement: step 3, image 1 of 1
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Motherboard Replacement: step 4, image 1 of 2 Garmin nuviCam LMTHD Motherboard Replacement: step 4, image 2 of 2
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • Disconnect battery wire from motherboard.
  6. Garmin nuviCam LMTHD Motherboard Replacement: step 6, image 1 of 1
    • Disconnect yellow ribbon cable from motherboard.
  7. Garmin nuviCam LMTHD Motherboard Replacement: step 7, image 1 of 1
    • Pull off black and red wire from screen.
  8. Garmin nuviCam LMTHD Motherboard Replacement: step 8, image 1 of 1
    • Disconnect the orange cable strip connected to the screen using a plastic opening tool, lift white teeth up and slide strip out.
  9. Garmin nuviCam LMTHD Motherboard Replacement: step 9, image 1 of 1
    • Remove silver plate from motherboard.
  10. Garmin nuviCam LMTHD Motherboard Replacement: step 10, image 1 of 2 Garmin nuviCam LMTHD Motherboard Replacement: step 10, image 2 of 2
    • Remove all six 5.74mm screws from motherboard using the T4 screw bit.
  11. Garmin nuviCam LMTHD Motherboard Replacement: step 11, image 1 of 2 Garmin nuviCam LMTHD Motherboard Replacement: step 11, image 2 of 2
    • Lift motherboard out of device using plastic opening tools.
3 other people completed this guide.
One Comment
Where to buy the replacement mother board? I couldn't find one.
BTW: Nicely done guide.
pitt83 - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 617
