Garmin Rino 700 Charging Port Replacement
  1. Garmin Rino 700 Charging Port Replacement, Battery Disconnect: step 1, image 1 of 1
    • Flip the Garmin Rino 700 over so that the underside is facing up.
    • Using the TR6 Torx Security screwdriver, remove the six 9.5 mm screws on the backside of the device.
  2. Garmin Rino 700 Charging Port Replacement: step 2, image 1 of 2 Garmin Rino 700 Charging Port Replacement: step 2, image 2 of 2
    • Remove the battery cover and set it to the side.
  3. Garmin Rino 700 Charging Port Replacement: step 3, image 1 of 2 Garmin Rino 700 Charging Port Replacement: step 3, image 2 of 2
    • Use the spudger to disconnect the battery wire port from the motherboard.
  4. Garmin Rino 700 Charging Port Replacement, Motherboard: step 4, image 1 of 2 Garmin Rino 700 Charging Port Replacement, Motherboard: step 4, image 2 of 2
    • Using the T5 Torx screwdriver, remove the two 6.4 mm screws on the motherboard.
  5. Garmin Rino 700 Charging Port Replacement: step 5, image 1 of 3 Garmin Rino 700 Charging Port Replacement: step 5, image 2 of 3 Garmin Rino 700 Charging Port Replacement: step 5, image 3 of 3
    • Using the nylon spudger, lift the motherboard out of its position.
    • Slide the motherboard out of the front panel of the device.
    • Carefully disconnect the motherboard from the panel and remove it out of the device.
  6. Garmin Rino 700 Charging Port Replacement, Charging Port: step 6, image 1 of 2 Garmin Rino 700 Charging Port Replacement, Charging Port: step 6, image 2 of 2
    Tool used on this step:
    Buy
Abigail Dugan
512 Reputation
5 Guides authored
Clemson, Team 5-5, Hunter Fall 2021 Member of Clemson, Team 5-5, Hunter Fall 2021
CLEM-HUNTER-F21S5G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 299
