Garmin Nuvi 56LMT Battery Replacement
  1. Garmin Nuvi 56LMT Battery Replacement, Battery: step 1, image 1 of 2 Garmin Nuvi 56LMT Battery Replacement, Battery: step 1, image 2 of 2
    • Before disassembling, power off the device.
    • There are four 11.0 mm screws located at each corner on the back of the device.
    • With the T5 torx screwdriver, remove these screws and set aside in a safe place.
  2. Garmin Nuvi 56LMT Battery Replacement: step 2, image 1 of 3 Garmin Nuvi 56LMT Battery Replacement: step 2, image 2 of 3 Garmin Nuvi 56LMT Battery Replacement: step 2, image 3 of 3
    • Using the plastic opening tool, pry apart the device around the seam.
  3. Garmin Nuvi 56LMT Battery Replacement: step 3, image 1 of 3 Garmin Nuvi 56LMT Battery Replacement: step 3, image 2 of 3 Garmin Nuvi 56LMT Battery Replacement: step 3, image 3 of 3
    • Observe the ribbon connecting the screen to the circuit board.
    • Detach the clip using the plastic opening tool and set aside the screen.
  4. Garmin Nuvi 56LMT Battery Replacement: step 4, image 1 of 3 Garmin Nuvi 56LMT Battery Replacement: step 4, image 2 of 3 Garmin Nuvi 56LMT Battery Replacement: step 4, image 3 of 3
    • Using the T5 Torx screwdriver, remove the two remaining 5.0 mm screws.
    • Lift the board from its housing and then detach the plug coming from the battery.
  5. Garmin Nuvi 56LMT Battery Replacement: step 5, image 1 of 1
    • If the battery is glued in place use the plastic opening tool to remove it.
    • Finally, exchange the old battery with the replacement.
Christopher Keller
102 Reputation
1 Guide authored
USF Tampa, Team S3-G5, Nance Fall 2017 Member of USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 416
