Garmin Nuvi 2689LMT Screen Replacement
  1. Garmin Nuvi 2689LMT Screen Replacement, Screen: step 1, image 1 of 1
    • Remove the stand by depressing the tab and rocking the round interface back away from the tab, pulling it away from the Garmin unit.
  2. Garmin Nuvi 2689LMT Screen Replacement: step 2, image 1 of 1
    • Remove the four 4mm hex screws from the four corners of the unit using a T5 bit.
  3. Garmin Nuvi 2689LMT Screen Replacement: step 3, image 1 of 1
    • Place the unit screen-side down flat, with the bottom facing you. There are two seams; the one on top is artificial.
    • This is the real seam—open it with a plastic opening tool in step 4.
  4. Garmin Nuvi 2689LMT Screen Replacement: step 4, image 1 of 1
    • Firmly force a plastic spudger into the bottom seam and pry open a section. Use a prying/pushing motion to force the tool into the unit until you feel a click.
    • Repeat this all the way around the seam.
  5. Garmin Nuvi 2689LMT Screen Replacement: step 5, image 1 of 3 Garmin Nuvi 2689LMT Screen Replacement: step 5, image 2 of 3 Garmin Nuvi 2689LMT Screen Replacement: step 5, image 3 of 3
    • Do not attempt to separate the unit until all the tabs have been separated. Once the seam is completely separated, you can lift the back away from the screen easily.
  6. Garmin Nuvi 2689LMT Screen Replacement: step 6, image 1 of 1
    • Retrieve a new screen and connect the flat-gold wire to the socket from where you removed the old screen.
2 other people completed this guide.
Spencer
273 Reputation
2 Guides authored
USF Tampa, Team 16-5, Eyestone Fall 2016 Member of USF Tampa, Team 16-5, Eyestone Fall 2016
USFT-EYESTONE-F16S16G5
3 Members
5 Guides authored
2 Comments
Were can I order a 6 inch screen for a Garmin Nuvi 2689 LMT
James Fraley - Reply
The screws will not come out. I have the screwdriver that was sent with replacement screen. Help!!
debbie_reeves - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,237
